Results 1 to 10 of 13
Thread: anyone here done a harness swap?
    how involved is it to pull a 2g n/a engine harness and replace it with a 1g tt engine harness? the engine will be pulled for this.
    i'm sick of running resistors (they are fugly sons of bitches) on my injectors. i can't use a resistor pack without the tt-harness apparently; so that's why i'm looking into doing this.
    on a side note, i haven't heard from shooter83 in eons, so i may end up shipping this to 3sx to have the tcu properly spliced in. is it better to have 3sx install it too; or just have them do the splicing? if swapping a harness is pretty straightforward with the engine pulled, i'd rather do it myself.
    Never finishes any verified
    Wake Forest, NC
    I have done it on my FWD TT. Really simple to do. The only modification I had to do to the harness was to wire in the front O2 sensor as the N/A front body harness does not have the front O2 connector. Everything else plugs right in! You will have to get a rear injector harness also as the plugs on the N/A Harness are different.
    I'm pretty sure thats all I had to do!
    I don't know about splicing in the TCU. Mine was done on a ATX converted MTX FWD TT. All TCU wiring was gone when I removed the N/A engine harness. I don't see it to be to complected as long as you are good at reading wiring diagrams and ECU Pin-outs
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    wait...the injector harnesses are separate? can i wire the resistors to the harnesses instead of at the injectors then? that would be WAY easier & i wouldn't have to re-invent tcu splicing.
    3sx was telling me that i could run a resistor pack off the firewall if i had the harness (but didn't specify WHICH harness). this is really what i'm looking to do. i want to keep the area around the plenum clean. it looks like canned ass on my motor currently.
    anyone?
    Wake Forest, NC
    The front bank injector harness is part of the main engine wiring harness. The rear one is a short harness that plugs into the main harness where those three plugs are on the intake plenum. The rear injector harness plug on the TT's is different than the ones on the N/A so you would need to swap out the rear injector harness.
    copy, thanks. i'm going to have to study my car in detail when i get home and make a decision.
    Charles Town, WV
    ^ that, I remember seeing a DIY replacement for the rear injector harness on the "other" side a long time ago, but the front ones are part of the main harness
    1995 VR4 Coupe
    should i just try and use this instead to cover up the harness?
    http://www.3sx.com/store/comersus_vi...dProduct=29122
    Charles Town, WV
    3SX Custom Injector Harness Cover 3000GT/Stealth*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
    It's a viable option.
    Personally, I'd source the spare harness. Then, remove every single wire that won't be used, things like EGR, ECS, or whatever. Then swap that in the car. There's miles of wiring that you probably don't use. When it's ready, replace, and sell your old harness.
    i would certainly consider it. my chief concern is having to re-wire the TCU to work with everything; and i don't want to do that.
