Page 1 of 11 123 ... LastLast
Results 1 to 10 of 109
Thread: Mitsubishi ASA JDM and USDM
    Twin Turbo verified
    Melbourne, Australia
    Thanks to VR-04-TT on Mitsubishi Club Australia [who got it of a dsm-club.org]
    Quote Originally Posted by VR-04-TT
    Since I've got it nutted out, I thought it's only fair to share this cool CAPS replacement program.
    Abiding by www.dsm-club.org 's request, I'll link you to the page and not directly to the file.
    Download the Japanese ASA for our car info.
    Click here for the page
    The files you want to download are the ones under:
    "Mitsubishi ASA Japan (MMC ASA)
    каталог запчастей MMC ASA для всех моделей Митсубиши японского рынка.
    MMC ASA catalog of parts for all models of Mitsubishi Japanese market.
    Обновляется через интернет.
    Updates via the Internet."
    The password for the archives is "dsm-club.org" (without quotations)
    Installation:
    Once you've downloaded and extracted the two ISO files. Just mount them (with Daemon tools) or burn them with Nero or something similar.
    Run disc A and choose "Setup". The program will start to install and you will get this first screen:
    Choose "English UK", click OK
    Next screen:
    Check the "HASP HL" box, make sure nothing else is checked.
    Click FINISH
    Next screen (after the HASP HL drivers are installed):
    Choose "Custom Install"
    Next screen:
    Choose your hard drive to install to, then check "Single User (Full) - Recommended"
    Click NEXT
    The program will install.
    Once this is installed, DO NOT start the program or it will give you an error message.
    You need to crack it.
    Browse your ASA Jap Disc A and find the "Crack" folder. Copy the file mmData.dll to this folder:
    x:\MMC\ASA\M00\PROG\ (where "x" is the drive you installed to)
    Then double click and run the MMC.REG file to update your registry.
    The program will now work.
    Have fun!
    Follow the same instructions for the USDM version etc. I have both installed on my Windows 7 PC.
    Final update to make this complete. I finally found a solution for those running 64bit versions of windows. I corrected some spelling and added some text but essentially all thanks goes to Frozen on OzVR4.com
    Quote Originally Posted by frozen
    i got x64 vista - possibly different. not sure. but that gives me an idea....
    edit - ok guys with x64 vista you will need to change the registry key that is being entered. Just open it up in notepad (right click, open with, choose notepad or choose edit if it's an available option)
    When inside, one line will say [HKEY_LOCAL_MACHINE\Software\Licenses], just change that to [HKEY_LOCAL_MACHINE\Software\Wow6432Node\Licenses] and save it, should work after that.
    the program is a 32 bit application, therefore runs in vista 64's 32 bit shell, which is kept seperate to all the 64 bit stuff. just like you have a Program Files and a Program Files (x86) folder in x64.
    Update:
    For alternative instructions and download links see this page. It also shows how to update to a newer version. Download links should also be password free.
    http://3sg.org/asa/
    Waiting install
    Build Thread
  2. The Following 6 Users Say Thank You to GTOJOE For This Useful Post:
  3. #2
    Good stuff. I need to get around to installing ASA
    Does this work with win7? I had this when I was running Vista, but no luck with win7 for some reason. Could it be that I'm now running in x64?
  5. #4
    Twin Turbo verified
    Works for me on Win7. One thing that did happen when I was installing was that the default install location was d: drive and I didn't notice so as it was installing then gave an error which threw me then went back and realised LOL.
    Alternatively try right clicking on the install file and go to properties. Select the compatibility tab and tel it to run in Win XP SP2 [not sp3] mode and so far everything has worked using this if it didn't before.
    Cheers,
    Joe
    Loveland, OH
    glad to see this made it out. when it first came out i asked about it (a good friend was the parts manager) and he didnt think there would be a way. he did give me all the old CAPS discs though.
    Twin Turbo verified
    Is there a technical section this could be moved to? I feel helpful things will get buried under pages and pages of posts.
  8. #7
    West MI
    Whats the difference between the us and jdm versions?
  9. #8
    The JDM version gives you all the Japanese market cars.
  10. #9
    Twin Turbo verified
    USDM only shows USA models and allows USA vin searches. JDM is on JDM etc. It's handy to have both so you can cross reference part numbers etc.
  11. #10
    Twin Turbo verified
    Bump for Ily on 3si..... and anyone who needs it. I finally got around to installing Euro ASA and General-Export ASA tonight [already had JDM and USDM installed]. Very handy tool to have.
  12. The Following User Says Thank You to GTOJOE For This Useful Post:
