So I disassembled my TC tonite in order to replace the spool. It appears that the ring gear has spun on the spool at some point. No evidence of spinning on the spool surface, just the shoulder that the ring gear is pressed to. Anyone have an issue with this? I measured the new spool @.001" larger.
So I have to reset the bearing preload for the spool and lash for the ring, any idea what the preload should be at?
