Results 1 to 10 of 13
Thread: NEW!!! Billet Triple ceramic ball bearing t3 kit
    Forum User supporter
    Oct 2010
    Rosemead,Ca
    Split Second Motorsports is proud to announce our SSM T3-BCTBB Kit
    SSM T3 SS Headers
    SSM T3 02 housings Vband
    SSM T3 V-Band 3" Down pipe with flex section
    QTY (2) Synapse external Wastegates
    SS Oil Feed and Return Lines
    3" Intake Pipes with K&N or AEM Filters
    QTY (2) COMP TURBO 6262 Triple Ceramic ball bearing dynamic seal in aluminum housings with a billet compressor wheel. also oil-less chra available at no additional charge
    3sGTO Price $5300.00 shipped
    Specs on turbos
    CT60 Compressor wheel, HE62 Turbine wheel .48 Non-Port T3 turbine housing with V-band
    Ahhh Comp turbo
    wish they'd hurry up with the TiAL stuff
    1996 GTO, Owner since 2003.
    Socal
    Ahhh Comp turbo
    Why, they are a Turbosmart dealer, better stuff.
    Pueblo, CO
    Ahhh Comp turbo
    Quote Originally Posted by pos-vr4 View Post
    Not Tial, TiAl... as in Titanium compressor wheels and Titanium/aluminum alloy shaft.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    Socal
    Quote Originally Posted by thor'svr4 View Post
    DOH!
    Seriously, these turbos by there design can run as high or higher shaft speeds even though they arn't tiAL
    Pueblo, CO
    so you need to redo the entire setup?
    Socal
    you mean like this...
    lol Thanks Thors...beat me to it.
    and while they are fancy they still have the added lag of the heavier turb wheel...not a whole lot of point to getting turbo's without it if your going all out since everything seems to be moving to TiAL.
    going to be keeping an eye out for when you guys DO do it though ;D (as I already have a set of Comp turbo's that could do with an upgrade.
    Kentucky
    So is this the same T3 header kit from the first post?
