Results 1 to 10 of 24
Thread: overhaul advice
    overhaul advice
    I'm considering doing a light overhaul on my engine.
    I'm still running a cast crank and strongly considering swapping it out for a forged one before it blows apart and contaminates everything with bearing material.
    I also still have the stock paper head gaskets that came on the early cars. I have some reason to believe they are leaking a bit of coolant. One of my plugs ground straps had a green tinge to it the other day and the car does not want to pull smoothly through the top of 3rd.
    Compression and oil pressure is great, so my real question is should I re-ring the engine while it is apart or leave well enough alone and just swap cranks and the head gaskets?
    There seems to be some risk in my mind to hand honing and if I get a machine shop to do it I may as well get it bored and go to forged pistons while I got it apart.
    Then I'd also get the rods checked for round, etc. etc. and quickly this turns from being cheap to a ton of money.
    I would spend the extra money on a complete rebuild.
    What is your end goal? Are you adverse to doing this more than once? It sounds like you have more time than money. If that is true then do what is needed now do the rest later.
    2006 - 94 Base model ; 2008 - 94 VR-4
    San Diego, California, United States
    No matter what you do for an "overhaul", you still need to have yours re-surfaced. Sry man, hope it works out.
    Quote Originally Posted by Atrosity
    Quote Originally Posted by CandyAppleVr4
    3S's have been turning normal people into mechanics since 1991. =P
    yeah you can say that again
    Wrench Monkey Not Verified
    Rochester, NY
    If you're going to go through the trouble of removing the pistons, then yeah I would replace the rings at least. I wouldn't ever hand-hone an engine I plan to put power to, but maybe you're braver than I.
    Slam a forged crank with new bearings in it, some new gaskets, pumps, and belts.... drive it till it blows. Hell, I did a crank swap in a vr4 with the engine still in the car and now it has well over 60k miles on it with great oil pressure.
    yeah I did a bearing and oil pump swap a few years ago that are holding up great. The prob is I may need to pull the heads and it may be easiest to pull the engine. If I'm going to pull the engine I'm going to replace the crank.
    So, I'm on the fence for either doing the head gaskets in the car or the crank and head gaskets out of the car. I do not want to change the crank in car.
    I'm going to do some more testing before tearing it down, it may be something simple causing the high load, high rpm mis.
    Quote Originally Posted by 1stStealthN/A View Post
    right and $2500 later how better off am I really when I have great compression and oil pressure now? Too many people do a full rebuild and their car never runs right again.
    Rochester, NY
    Ain't that the truth.
    don't jinx me, mutherfuckers!
