lol that's the truth!
I don't think most people get the engine rebuilt correctly. I'm a bit shocked to hear that you are contemplating replacing rings. I guess I should read this whole thread then comment. I'd never replace head gaskets and crank without honing cylinders and replacing rings. I'll read the thread and comment more.![]()
i'll interject here to say that i DON'T think it's a 3/s specific problem.
i think that a LOT of people think they know how to do a rebuild, and probably only half of them actually do. hell, i don't know how to do it; and that's why i'm having someone who HAS done it help me out. there's a lot more to it than "bolt this onto that".
certain types of sealant can't be used in certain areas. certain types of gaskets work better in some areas than others. not all machining work is equal; but paying through the nose doesn't mean you'll get quality either. some people forget to replace EVERYTHING when they rebuild; and a used oil-pump, used water-pump, used balancer, etc is NOT getting off on the right foot. unless you've been around the "block" before (usually which involves previous rebuilds with some degree of failure) you likely won't know what you're doing.
all i'm saying is don't fault the idea of a rebuild. ray tore his engine down recently to "freshen it up"; it's not a bad idea. the key is knowing what you're doing. there isn't ANY margin of error on a motor you are trying to rev to 9000 rpms.
