I'm considering doing a light overhaul on my engine.
I'm still running a cast crank and strongly considering swapping it out for a forged one before it blows apart and contaminates everything with bearing material.
I also still have the stock paper head gaskets that came on the early cars. I have some reason to believe they are leaking a bit of coolant. One of my plugs ground straps had a green tinge to it the other day and the car does not want to pull smoothly through the top of 3rd.
Compression and oil pressure is great, so my real question is should I re-ring the engine while it is apart or leave well enough alone and just swap cranks and the head gaskets?
There seems to be some risk in my mind to hand honing and if I get a machine shop to do it I may as well get it bored and go to forged pistons while I got it apart.
Then I'd also get the rods checked for round, etc. etc. and quickly this turns from being cheap to a ton of money.
