Ok what do I need to do/buy for a replacement antenna? One of the ebay specials ok? I need to test the unit I suppose and see if the motor works and just replace the mast if it does or go ahead and swap the whole thing out?
Here you go.
Shark II antenna.
www.LoCustom.com
Its a small antenna like the ones on S2000. Looks much nicer than the stock one.
I bought a $12 rubber mast antenna from Autozone, and it worked great!
Hey, when you turn your car on, does it return the favor?
Originally Posted by Michaels_RT
I'll check cherry hill. I don't want something that doesn't retract. Thanks for the input guys.
Try to get one of these - I sell a shit load of them and they are unreal...
Blaupunkt Auto Fun Antenna
Got one from 3sx and although i spent just a tad bit more, I was extremely happy with it knowing it was not only going to fit, but easy to install with the help of this link!
Stealth 316 - Power Antenna
works like a charm!
STEVE-O
'92 VR-4 - '99 Front End Conversion - Galaxy White
Isn't there an antenna that mounts on the back window glass? Kind of like a stealth antenna?
I'm going to get a replacement mast from Cherry Hill if the motorized unit is still working. I forgot to test it the other day while I was there working on the car. I would like to keep the stock setup if I can. We'll see how it works out.
