Results 1 to 3 of 3
Thread: Anyone Local have ATX they aren't using (DelMarVa)
    Member Not Verified Feedback Score 0 Dbeltran24's Avatar
    Silver Spring, MD
    So after the big snow storm we got recently, I now have a pretty big Transmission Fluid Leak. Not sure where its coming from yet.
    I haven't been able to lift the car, due to all the Ice and snow around. The last thing I want is to lift it then watch it slip and drop, especially if I'm under it.
    So does anyone local have a spare ATX laying around? (Just incase the leak is actually something major)
    I have a 99 3KGT SOHC. Although I don't think that makes a difference. I believe all the NA's used the F4A33 Auto Transmission.
    I'll update this thread once I have my car lifted. But until then, anyone with a spare ATX, please chime in.
    Thanks,
    David
    There are indeed differences. The F4A33 designation is used for DSM FWD ATX's as well.
    Past information I found indicated
    91 SOHC and DOHC share a part number
    92 SOHC and DOHC share a part number
    93 SOHC and DOHC share a part number
    94 SOHC and DOHC share a part number
    95-99 SOHC share a part number
    95-99 DOHC share a part number
    GREASE BUNNY Feedback Score 0 Granny's Avatar
    VA
    IPT is your only friend.
