Closed!!!!
After talking more to them i found out they would not warranty the two piece aluminum shaft because the carrier bearing would be riding on aluminum. which is for race use only because they will not last too long. So we renegotiated on providing just the second half to your existing drive shaft replacing the second and third piece. as well as the typical steel aluminum combo. and came up with 700.00 for the combo shaft with oem replacement carrier bearing and 500.00 for just the second half(replacing stock 2nd and third pieces) I am having mine done right now and will post up more info on them later
