Results 1 to 8 of 8
Thread: need to tow the VR4
    Cazenovia, NY
    need to tow the VR4
    OK, so I need to make absolutely sure that this is safe before I do it.
    Gotta tow the VR4 as it's not on the road and I'm moving. Can I disconnect the drive shaft at the rear diff and use a tow dolly? No one around here carries flat beds.
    Cazenovia, NY
    No one? Surely this has been done. I've seem some threads on it but none with a solid yes or no.
    Yes you can. I've done it a few times.
    Rancho Cucamonga, CA
    ^What he said. You'll be okay if you disconnect the driveshaft.
    ...AND tow it on the rear wheels. just so we're clear.
    Cazenovia, NY
    Thanks guys. Hans, when you do it do you just disconnect the flange from the diff and tie it up somewhere or do you have to remove other parts of the shaft?
    Just unbolt it from the rear diff and tie the driveshaft up out of the way. I've done it this way on more than one occasion.
    Forum User supporter Feedback Score 5 (100%)
    Oct 2010
    Rosemead,Ca
    Just an FYI. I would just tie it up but for some reason if you feel the need to disconnect just the rear part of the drive shaft be sure to mark it before hand so it install the same way and you dont screw up the balancing of the shaft
