Results 1 to 10 of 20
Thread: ok...so how do i put one of these in my car?
    Warner Robins, GA
    In the late 40s/early 50s, GM had what amounted to an "infinite" automatic gearbox. Oldsmobile called it "Hydro-Matic" and Buick designated it "Dyna-Flow" IIRC. It essentially had no noticeable "gears". Maybe we're headed there again?
    Warner Robins, GA
    But, to answer your question: "With great amounts of cutting, fabricating and welding."
    Lacey, WA
    What about the CVT transmissions that a lot of the hybrids have? Wouldn't that be best for power and economy?
    Stuper Moderator
    January 2003
    Quote Originally Posted by BaadVR4 View Post
    I'm not following what you mean on "infinite automatic gearbox"? Those two transmissions are quite different.
    The early hydramatics had no torque converter, they had 3 planetaries and a fluid coupling(I've got one in the garage in the form of a 53 Pontiac). Dynaflow relied solely on a tq converter and yes it was extremely smooth, as in you couldn't feel them shift at all(they only had two forward gears though, where hydras had 4). Early hydramatics have no "park" setting. After you shut them down, you put it in reverse and it locks the driveline. People always flip out when they look at the selector in my Pontiac. Then they really flip when I tell them it has no oil filter, haha.
    I'm fairly into old Pontiacs and Buicks, got one of each.
    Douches
    Advanced Tech? verified
    Quote Originally Posted by 91stealthrt2 View Post
    The problem is that "CVT" is a catchall term for many different kinds of transmissions, and so far most aren't reliable enough for the loads greater than produced by a dinky hybrid engine. another problem is that most CVTs have much higher power losses than traditional gears because they are friction-driven. This means heat (and thus reliability).
    BINGO.
    which is why the evo's now have DCT's, not CVT's. and i'd be happy to put a DCT in there (paddle-shifters and all) if it was remotely feasible. unfortunately, it's about as simple as putting one of these 8-speeds in. (which is to say it's not).
    So chicks must be pretty excited about this.
    Warner Robins, GA
    You are absolutely correct. I was commenting on the evolution of gear boxes having ever more speeds, with a touch of sarcasm about how we seem to be headed for a trans which would act like it had an "infinite" number of gears like the early GM units. I remember the advertising for the Buick Dyna-Flow in particular made a big deal out of the smooth application of power without any noticeable gear shifting.
    BINGO.
    People can't even reliably swap the SSTs in the Evo, so good luck swapping it into something else. I test drove one of the SSTs, it sure is friggin sweet. If I had to commute into the city more often, I would have considered buying that instead, but the price penalty wasn't worth it, IMO.
