Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Oil filter relocation kit and engine oil levels?
    more/larger filters is in theory larger time between filter changes and in theory lesser back pressure induced by the filtering process, easier as in you don't have to get your hands up there and possibly a tool to get up there and change the filter, instead you can simply lean over the engine bay and off you go.
    1996 GTO, Owner since 2003.
    Advanced Tech? verified
    double filters = almost zero pressure drop
    Jan 2011
    Orlando, Florida, United States
    Greddy Generic Unit?
    GReddy 12004901 Oil Filter Relocation Universal Kit
    Actually, it appears that we run the same Mobile One oil filter as the Acura Integra, 1.6, 1.7, & 1.8L blocks, from years 88-01, so, we should be able to run the following specific kit:
    12054901 - http://www.alamomotorsports.com/gred...elocation.html
    The only drawback is that Greddy recommends you run their specific filters, which I'm unfamiliar with, quality wise.
    This would make it quite a bit easier to run the hamburger/sandwich style oil pressure gauge option, without creating too much of a low point under the vehicle to worry about bumping/dragging.
    wow those are expensive for bugger all
