Results 1 to 10 of 18
Thread: very odd 6 speed problem
    Jan 2011
    i have talked to a couple 3/s guys and havent had anyone else with this problem yet. i broke and a shift fork and i had a local place replace it and he told me my trans was great. 2 weeks later it was grinding in 2nd and 3rd. befor i could get back to him i was driving it and was shifting from 4th to 5th and hit 3rd. i then tried again and my shifter would not move to the right (i couldnt get 5th 6th or reverse). i then had family issues and was not able to deal with the guy that rebuilt it. i went out the other day and it would get every gear until it warmed up and then i lose them again. let it sit a couple days and everythings back until it warms up. this is in a 94 vr4
    Im not sure what your problem is, could have broken or bent the fork again, or it could have been a poor repair.
    Either way i would'nt drive the car anymore until the issue is fixed, you risk making the problem worse and damaging other parts that might not be hurt yet.
    -Austin
    And the list goes on...
    Jan 2011
    its parked right now. i thought a shift fork at first but i was told 5th and 6th arnt the same
    Ask them what they used for trans fluid. I had a similar issue with using straight 30 weight engine oil. That was the first and last time I did that LOL.
    Jan 2011
    i will check i added a bottle of lucas to stop the grind and it never overflowed i guess it could be stupid low or he may not of put any in as dumb as that sounds but its been sitting and there is no drips or signs of it leaking either
    Check your clutch adjustment. Under the peddle you know. If adjusted too low, shifting will be a bitch.
    Jan 2011
    thanks guys ill keep u guys posted when the snow melts
    Brisbane Australia
    Has it melted yet?
    "Video games don't affect kids, I mean if Pacman affected us as kids, we'd all be running around a darkened room, munching pills and listening to repetitive music."
    PIONEER-ODR RS-K1/C-100/C-200/RS-P50 X2/RS-P1/RS-M1
    DIAMOND-AUDIO HEX 8" X2/HEX SILK DOME TWEETERS X4/D7-401 AMP X2/D7-402 X1/D7-152 AMP X1/D7-104 AMP X1 ETON 4-300/25HEX 4" X4 AUDIO-CONTROL EPIC-160
    ECLPISE 10" TITANIUM (SUBSONICS) X2 SW9102
    PHOENIX-GOLD 12" CYCLONES (INFRASONICS) X2 DC SERVOS http://webfaq.phoenixphorum.com/cyclone.htm
    FUSION 7 COLOUR L.E.D KITS X4 2 MODIFIED. Intergrated lighting through out install.
    1994-MITSUBISHI-GTO-TWIN-TURBO-4WD-4WS-FULLY OPTIONED-SERIOUSLY being MODIFIED
    Jan 2011
    nope theres still about 3 inches of it here
    Brisbane Australia
    Get the missus hair drier out then
