First up is my stock turbos, they have been great to me for the 2 years i've owned the car. They now have 80k on them and are still nearly perfect! This is the first time they have been off of the car.
As most of you know these turbo have been pushed to the max, i raced with them several times in the time i have had the car, and never once had an issue with them.
On the dyno they squeezed out 23psi and on the track ran a consistent 19psi every single pass. Never a puff of smoke and the intercooler piping doesnt have a spot of oil in it.
I'll start at $350 for them, still bolted to the headers so no broken bolts
- also all lines are still attached and ready to bolt right in.
- Next up is a great condition fuel sender, all the connections are good, the feed line is just barely rounded, but still very usable. There is just a little bit of surface rust but otherwise mint.
$100 for just the sender, or $150 with the walbro 255 in it.
- I have a used walbro as mentioned above, couple years old, but no issues ran great pressure, and wasnt run dry.
I'll take 60 for it, unless it sells with the sender.
- Also have the tank for sale, some surface rust on the top, but still very nice, and not dented at all. Never seen a winter and about as nice as it will get without being new.
Not exactly sure what its worth so I'll say $100
- Had this sitting in a box for a year, forgot i even had it. Worked fine when removed reads up to 40 psi hass wiring for the light, and the fitting for the vac line. Only need screws or clips to hold it in place. Comes with the pod
I'll let it go for $30
If there any interior parts, or random brackets let me know, i still have everything i have pulled from the car for the most part
-a/c pump
-abs pump
-SMIC's and piping w/ aluminum y-pipe
-all electronics
-speakers
-sun roof cover
-mint charcoal dash
-seats
-seat belts front and rear
- and a whole bunch more
Just make an offer, i'll let it go really cheap just to clear up some space.
Also if you want some new parts for install, I can cut you a deal on that to.
Paypal is Thebird65@aol.com
-Austin@STM
