Results 1 to 5 of 5
Thread: A/C High Pressure Relief Valve
    Formerly OwnGTP/WantRTTT Feedback Score 0
    April 2004
    Houston, TX
    Anyone know where to source one of these bad boys? The small relief valve that threads into the manifold on the compressor. I've replaced everything else in my a/c system and there's still a leak. Sometimes the relief valve pops so I think it's the culprit and I want to put a new one on there.
    Tony M.
    2002 Jeep Grand Cherokee Overland - There's Only One.
    1995 Dodge Stealth R/T Turbo - Gone but not forgotten . . .
    “The danger to America is not Barack Obama but a citizenry capable of entrusting a man like him with the presidency. It will be easier to limit and undo the follies of an Obama presidency than to restore the necessary common sense and good judgment to a depraved electorate willing to have such a man for their president. The problem is much deeper and far more serious than Mr. Obama, who is a mere symptom of what ails us. Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. The republic can survive a Barack Obama, who is, after all, merely a fool. It is less likely to survive a multitude of fools such as those who made him their president.” -- Author Unknown
    Oct 2010
    I've had the same problem, but I think it's just the compressor.
    Too high of a pressure has to be a clog, right?
    April 2004
    Houston, TX
    Well it depends. My pressure looks good with the gauges hooked up, where I was seeing trouble was driving in 100+ ambient temps with the FMIC. Airflow wasn't as great through the condensor so the pressure rose. In my opinion, I doubt it ever rose to levels high enough to be dangerous, but I do think that valve is shot and thus, was releasing freon. That and I think it probably stuck open a bit after relieving the pressure, thus continuing to leak freon out until it was all gone.
    That's my theory as I've replaced every other component on the system. Since the manifold for the compressor carries over when you buy a new compressor, I'm thinking that valve is the culprit.
    XLR8TOR Feedback Score 0
    Las Vegas, NV
    We had our A/C relief valve blow in Blyth, CA when it was 118 degrees on our way to San Diego from Vegas. Liked to killed us driving across the desert.
    Turned out it was because someone had converted a '93 to use R-134 instead of R-12. 134 creates a lot more pressure combines with the extra heat and Ka-boom. The valve was history. DO NOT let someone convert your R-12 system to R-134 on these cars or you will run into the same problems.
    Turns out most reputable A/C shops can find a replacement valve so check with them first. Don't let anyone tell you that you must replace the entire unit because you don't have to.
    April 2004
    Houston, TX
    94+ cars were 134A from the factory so no worries there.
