Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: **GZP Front and Side Mount Oil Cooler Kits**
  1. #51
    In my eyes, if your idle oil pressure did go up, its a false sense of "better" and if anything is restricting volume flow rate.
  2. #52
    rawr. verified
    August 2009
    San Diego, CA
    I am not sure what caused it to go up, The only thing i can think of is leaky oil lines...
    https://car.social
  3. #53
    damn man if I ever saw 8 PSI I'd have the oil pan off that day.
  4. #54
    -BOOSTTD- verified
    Elko, Nevada, United States
    Ya 8psi scares me lol I'm scared when mine hovers around 12-15psi
  5. #55
    Quote Originally Posted by mh3kgt View Post
    yeah I would too. You guys need to put some new bearings and oil pump in if you haven't Mine used to be 12 too, but has been running 20 PSI at 850 RPM now for 4 years.
  6. #56
    -BOOSTTD- verified
    I think mine is actually about 15-20psi when warm. I just have a cheap Glowshift gauge tho, so who knows how accurate it really is. Engine is new build with ~1k miles so far. I had Donniekak build it for me.
  7. #57
    rawr. verified
    August 2009
    San Diego, CA
    My car is getting new paint and 99 converted then after that I will be saving up to take the oil pan off for a new pump and bearings. I barely drive the car so It'll sit for a little bit until this issue is fixed. :P
  8. #58
    good plan
  9. #59
    rawr. verified
    August 2009
    San Diego, CA
    Raised my idle to 800-850 and now my oil pressure is consistently reading 18-20 psi and after numerous of wot pull 15-17 psi after boosting.
  10. #60
    Wilmington, DE
    Does this kit come with the adapter to the oil filter housing for the lines? I know when tu buy this kit from other places its a separate purchase. Is there anyway this kit will bolt to the stock location instead of pushing it to the passenger side?
