Originally Posted by
sergechronos
Not to renecro a mostly dead thread, (although mostly dead is still partially alive), but given that you said the Walbro has less current draw and is likely less tolerant to slow downs (in regards to dual Walbro), would this mean that the dual resistor idea may not work near as well for a single Walbro as it did for the Denso? Or should it still work fine?
I've been running a Walbro single but had yet to hotwire it as I was still running stock FPR, Injectors and Turbos. Now I'm going to be going to 560cc, 13ts and replacing the FPR (most likely with another factory FPR if this works), and would rather do dual resistors than hotwire and AFPR.
