Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Erik Gross method revisited
    Wrench Monkey Not Verified
    Rochester, NY
    This is cool stuff. Kudos OP.
    Have you noticed any issues yet ? Im thinking of trying a single walbro 450 with dual stock resistors. I'm really trying to avoid going the afpr route this time.
    Medford OR
    Quote Originally Posted by mb7050 View Post
    I've had it in my car for over three years, and probably somewhere around 20K miles... I'm running 550's now, still works great.
    The only concern I ever had was the switch point climbing up with piggyback airflow adjustments... That hasn't been an issue with up to 550's at this point. If you had a clone ECU and Greg's software you could adjust it anyway....
    I've got the same system in a Walbro 255 equipped car with 450's works great in that one as well.
  4. The Following User Says Thank You to RealMcCoy For This Useful Post:
  5. #24
    I'm bent because it "should" have worked.. and go on a mission to find out why it didn't..
    This is the way I found 90% of the stuff I learned working on race cars. "Huh, that's funny" coupled to hard, objective data obtained during an investigation ultimately produces results.
    I wish more people worked like that. Good job.
    Everybody else: could we maybe stop with the jokes and inside references? This isn't Reddit; the noise is drowning out the signal.
    DG
  6. #25
    Quote Originally Posted by DG View Post
    DG
    LOL, DG you are yelling about comments made well over a year ago...
  7. #26
    Still applicable.
    And how does your comment add value?
    DG
  8. The Following User Says Thank You to DG For This Useful Post:
  9. #27
    About as well as yours I guess?
  10. The Following User Says Thank You to CoopKill For This Useful Post:
  11. #28
    I confused why not go to the AFPR. I have a supra pump hot wired and a AFPR, did not see any pressure issues?
  12. #29
    I lack color... verified
    Aug 1998
    Quote Originally Posted by pat3000gt View Post
    Because its cheaper and easier to rewire the fuel pump the way Mitsubishi intended.
  13. #30
    because the afprs have a tendency to leak down very fast and causing longer cranking times.
