Alright. I replaced my bad CAS and my car started and ran for like 30 seconds then died again. So I tore aveything back down and found this
It looks like the trigger wheel has carved into the CAS. Would that make it stop working all together?
The trigger wheel is likely your issue. If its not in its proper place the coils will not fire at the right time.
Alright, how do I tell if the trigger wheel is out of line?
Here is a pic
It's pretty hard for the wheel to be out of place as it fits on the keyway. The fact it's hitting the sensor is prob the problem. It might be too far away from the sensor to be picking it up. Has one of the tabs been bent or anything?
Waiting install
Build Thread
Not that I can tell. If you look closely at the picture you can see where the edge of the bottom two the blades are clean, so there must have been contact with something. Also, just to the right of the lowest blade there is a clean ring where the wheel mist've been hitting. Just the the right of the Should I just replace it and the cas?
Alright. Looks like I'm pulling the timing belt then! How fun.
Are you sure you didnt somehow put the new CAS in wrong causing it to make contact with the blade? Maybe you didnt tighten it properly?
I don't know, I'm just trying to throw other ideas out there before you go pulling the timing belt for nothing.
I may have put the CAS in wrong. Is it possible to overtighten it? None of this could be my problem, I'm just at the point where I'm going to replace shit until it starts
Here is my other thread where I tried to diagnose my no spark problem.
I think both you and GTOJOE had a couple of posts.
