Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 112
Thread: My Twin 20G Build
    Forum User Feedback Score 0
    Houston
    My Twin 20G Build
    Hey guys, I thought I'd post this thread up here to share pictures and keep my progress on this car updated as often as possible for you. There is a lot of custom work done to this car which I am willing to discuss. I am also very open to criticism, suggestions, questions, and anything else that can contribute not only to my build, but the community as a whole.
    Alan, is it ok that I post the link to my old thread on 3si as a reference? I know there were a lot of important questions and topics discussed, and it would be a waste to just throw it away.
    I am going to also reserve the next couple posts to keep the pictures in a nice, orderly and presentable fashion to track the progress from the beginning to the very end.
    What does the build consist of?
    Twin TD06H-20G Compressors mated to TD05H 6cm Turbines with internal wastegates welded shut
    Tial 38mm Wastegates and BOV
    Custom built Equal Length Longtube Headers and O2 Housings
    GT-PRO FMIC
    2.5" Custom Charge Pipes from Turbos to FMIC
    3" Custom Charge Pipes From FMIC to TB
    Custom Driver's Side Intake Manifold with 90mm Q45 Throttle Body
    DR Stage III Heads and IPS 272 Cams
    UR Cam Gears
    ARP Head Studs
    AEM EMS with all accessories
    PTE 780cc Injectors
    Twin Walbro Fuel Pumps
    SSB Fuel and Oil Lines
    Aeromotive AFPR
    Mishimoto Radiator and Slim Fans
    Corbeau Fx1 Pro Seats, Harnesses and Brackets
    Broomfield Racing Billet Transfer Case Housings and 300m Output Shaft
    What's left to do?
    Oil Feed Lines
    Vacuum Lines
    Transfer internals and Install transfer case
    Install Timing Cover, Heater Hoses and Spark Plugs
    Put the rest of the interior together
    Tune the Car
    Pics of the car before the build began:
    Houston
    Build Pictures:
    Houston
    Houston
    Houston
    Still under construction -_- Not Verified Feedback Score 3 (100%) MNRVR4's Avatar
    Hubert, NC
    O_o ........ O...M...G im in shock right now lol, how long has it take you so far? From when you started to where you are right now? Keep up the good work man! and let us know what she puts out!
    Houston
    Forum User Feedback Score 1 (100%)
    AHHHHH Holy shit that is badass, you're doing a fine job with all that fabrication :O
    Hot damn. That is badass. Great fab work!
    Houston
    Markoverclock from Turbochargers.com is doing 99% of the fab work. I just installed the seats and thats about it. I give him a helping hand whenever he needs is, but I dont have the technical expertise to do any of the fab work shown in the pictures. In fact, you can see him in some of the pictures. It has taken 2 1/2 years so far working a couple hours on a few Sundays each month. This actually went from a simple header/turbo fab into an all out build. The might as well syndrome kicked in very early on.
