Hey everyone,
so after a week of really productive work, I go for a test drive and my car dumps PS fluid and I lose power steering. No problem I think, I will cut out the leak and replace the pipe. Well the leak is on the tube right where it connects to the rack, right at the end so no cutting it out.
Its freezing here so I dont feel like replacing the whole line so I was thinkng about doing this, let me know if it would be a problem in a PS system. I was going to get the replacement tube, cut the last few inches off the new one, cut off the last few inches of the old one and then connect it to the existing tube with high psi tubing. The rest of my tubing has absolutely no corrosion so im thinking this is a quicker alternative to replacing everything in this weather.
I have done this with A/C lines after repairing older cars in accidents and its always worked well.
Thanks for any advice![]()
I'm pretty sure the line going to the right is the low pressure line, and feeds into a rubber line to move up along the frame towards the P/S fluid reservoir. I don't have a service manual handy at work anymore, so I can't check to be certain.
