Results 1 to 10 of 14
Thread: Advancing timing for low end torque
    Ft. Lauderdale, FL
    I want to make the car a little quicker off boost. I assume advancing ignition timing (via emanage) can achieve this to a certain extent. Is this common practice? I figure off-boost, the car is pretty unlikely to knock, so there should be a pretty wide window to advance timing. Would it slow turbo spool significantly? I kinda doubt it would make a whole lot of difference with 9bs. Any other downsides to doing this?
    Ft. Lauderdale, FL
    Just remembered that emanage blue can only retard timing... damn. Still would like to know if others have done this with standalones and such.
    Feedback Score 6 (100%)
    Quote Originally Posted by RL7 View Post
    really? I'll have to double check but I have some areas of my map advanced. Is it doing nothing then?
    I thought EMB could advance or retard timing. I never had one, so I don't know for sure. Maybe I'm mixing the capabilities of the EMU and the EMB.
    CT
    I was under the impression that it can only retard as well, but cant seem to find anything to back it up.
    Forum User Feedback Score 0 jbuhrman's Avatar
    Dec 2005
    Williamsport, PA
    It'll knock
    And you know this how?
    Quote Originally Posted by jbuhrman View Post
    Its quite simple really, everyone's ringleads are shit and any engine work/mods you have done are trash.
    It likely would knock. I could easily induce knock by using a higher gear and rolling into the throttle instead of shifting down. Even just going WOT would make it not knock. Good for the car? No, not at all, but easy enough to avoid. Retarding timing just makes it worse, it feels completely gutless. Honestly, if you want more off-boost power with 9b's.... Shift down and make it boost.
    ~2006
    Pittsburgh, PA/Wheeling, WV
    You can advance with the EMB. Really depends on your setup if it'll make more power. The factory map is probably pretty optimized but may be able to use a tiny bit more if your running 93 compared to 91. If your on E85 you need more timing/etc.
    I would not recommend it unless you have mods/a tune that would require it, however, as low RPM/high load situations make knock easy to come by and advancing timing will just make it easier.
    Forum User supporter Feedback Score 1 (100%) Rocket's Avatar
    To get more low end torque would mechanically advanced cams be more helpful than just advancing the spark timing? By moving the entirety of the timing forward you may get some more low end torque, but just advancing the spark I am not sure there would be much of a benefit. No idea on the knock with spark advance, seems you could push close to knock.
    Brandon
  • History
  • Information
  • Groups
  • Events
  • Resources
