Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 78
Thread: ***NEW***GZP Belly Pan***
    -BOOSTTD- verified
    Elko, Nevada, United States
    We had no issues with a 14mm deep chrome Snap-On socket. The final production should have enough clearance for an impact socket.
    Awesome! This "may" somewhat ease my paranoia of joining the Spun Bearing Club
    Wrench Monkey Not Verified
    Rochester, NY
    How much does that thing weigh? Also, how is that going to protect the oil pan from someone jacking up the engine by it? Isn't that how almost all of them get dented?
    Looks like it'd be good for aerodynamics at least. Subscribed for final pics and price!
    Ask Stealthee if this would have helped his oil pan and filter
    I'll have to weigh this one, but this won't be the material the final product is made out of. This is just cold rolled steel to save on costs in case we screwed it up. Stainless and Aluminum should be a bit lighter.
    It should also help on keeping your engine bay clean.
    It won't help you if you use a dumbass mechanic. I do have an idea for that though that will be in the works next week.
    seize the carpe!
    I want to see this said diffuser/ plate setup.....
    I'm waiting for some parts to come in so I can make it.
    2004/5?
    SW Connecticut
    Ballin'.
    Excited to see the front diffuser as well!
    I don't know how much ventalition the engine gets from underneath, but perhaps you could add some ducts to help bring some cool air into the bay? Seems like this would make the running temperature increase a bit.
  8. #18
    seize the carpe!
    Quote Originally Posted by Amphiron View Post
    you would think it would increase bay temps but if designed correctly it helps decrease bay turbulence and actually cools much better. the ideal design would incorporate hood venting as well.
  9. #19
    I'll be sure to take some temperature readings to see if it is necessary for ventilation with this belly pan.
    I know I plan on running this pan with Cianci's Victory hood so I have a louvered hood to release any engine bay heat. But, we will definitely do some testing this weekend to see what effects it may have on the under hood temperatures.
  10. #20
    you know you like it Not Verified
    Sacramento CA
    Quote Originally Posted by DanF View Post
    There are still working AA systems out there?
    Yes Mine
