Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 113
Thread: Saved From The Crusher - 93 Stealth TT Rebuild/Restore
  1. #41
    ***** Abuser
    Northern Virginia
    Impressive. The paint looks like it is coming along nicely. That car looks a million times better than when you got it.
  2. #42
    Never finishes any verified
    Wake Forest, NC
    So the car is all back together "Minus some small parts" But I can't get it to start up now. The engine will crank just fine but won't fire up! Makes no sense as it ran fine in the FWD frame. I made no adjustments to the engine or any electronics/sensors. Even the damn engine wiring harness was swapped over!!!
    I started a new thread for the engine issues. Hopefully I can get it running in the next week or so.....
    http://www.3sgto.org/showthread.php?...3657#post33657
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. #43
    Wake Forest, NC
    OK so here is what I have for updates so far!
    I have been getting a few packages over the last couple of weeks. The first one I received was the underbody panels for the 99 front end and the top metal trim pieces. I am still missing one of the center panels for the 99 lip. I also found out that the wheel wells plastics are also not the same so I will have to hunt a set of those down also.
    I also received a nice package courtesy of Austin at STM motor-sport:
    The hardline running from the tank to the fuel filter had been damaged prior to me getting the car. I tried to repar it with brass compression fittings without much success. So I got Austin to piece me together a -6AN fuel line kit to replace the hardline. I love the braided black lines and the black/silver fittings. I am going to have to order more of them to replace the blue/red fittings and SS braided line going to my fuel rails later on down the road. I also order one of there 14lbs sealed batteries as I am relocating the battery to behind the rear seats. Man that little battery has some juice! It lasted for about 30 cranks over 3 hours before I had to put it on the charger!
    Last but not least is a sneak peak at the last item I got in today! It was a very big box and I will say just looking at the pieces I am seriously impressed with the construction and the quality of the materials. You can read about that in this thread:
    http://www.3si.org/forum/f56/ebay-ex...2/#post6075488
    Here is a sneak peak of what I got in today:
  4. #44
    Glad your happy with the parts, let me know how that fuel line works out for you, if everything goes well i will add it to the website, if it needs any modifying let me know what you need different.
    -Austin@STM
    And the list goes on...
  5. #45
    Real drivers don't use speed limits verified
    Buffalo, New York
    Wow, your car looks like mine when I first got it, cept I had body panels :P Looking great tho!
  6. #46
    94 3500gt vr2? verified
    NC
    if you need stock parts, i have a garage full of them, lol
    i know 1st and 2nd gen splashguards aren't compatible, but not sure about 2nd and 3rd gens
    anyway, i have 2nd gen splashguards, 3 sets of charcoal doorpanels in usable but not perfect condition
    only an hour away if you need anything
  7. #47
    Wake Forest, NC
    It's Alive!!!!
    I don't know what the hell I did but the car is finally running! It is running really rich right now as I need to get it properly tuned but I am just stoked that it is finally running.
    Below is a video I made of the car running to show the ebay exhaust I bought:
    Ignore the smoke the car is running really rich right now and it sat for some time in the cold weather...
  8. #48
    N.C.
    Damn...it sounds GOOD!
  9. #49
    Wake Forest, NC
    So I have been spending a lot of time latelty getting little things fixed here and there. I am having issues with the fuel pressure so I am waiting on a FuelLab FPR to come it. Spent a few hours yesterday trying to get my EBC to zero out. it has been driving me nuts as at idle it kept sawing I was at 20psi...WTF! I had to open it up and manually adjust the solenoid to zero it out. Now it is reading correctly.
    Then to top it all off I come to find out that I am not boosting at all! I can here the turbos wind up but I am not building and boost. I believe I have a wastegate open causing back pressure and not building any boost. I have to dig into it and find out exactly what all is going on with it. I hope to have some time to tinker with it during my 4 day holiday break.
    I also need to find out why the break pressure is crap! I know I have a frozen rear caliper and my assumption is that there is air caught in that rear line that I cannot bleed out. I need to swap it over and see.
    Once all of the small issue are fixed I will take it out to get it inspected and hopefully registered.
  10. #50
    Fuck that sounds tough as guts.
