08-31-2010, 09:17 PM
I got the Heim joints in today from SpeedwayMotors.com. Really fast shipping and the quality is great.
I am only missing the sway bar end links now and the rear end will be complete. I am still going to install it tomorrow as I have brake work that needs to be completed and the sway end links are easy to install.
I also as able to get some of the engine bay items re-installed. Non-ABS prop valve and lines where installed along with the clutch and some of the A/C lines.
Next on the list is repairing any issues with the body wiring harness and re-wrapping it with new electrical tape as the old tape is brittle and cracks easily.
09-01-2010, 03:42 PM
I used the same parts as are listed in this thread:
http://www.3si.org/forum/f116/aws-de...-i-did-367862/
Parts came out to like $95.00 including shipping. I picked up the bolts at a local hardware store. The joints are really nice and self lubricating from what I can tell. Shipping took like 2-3 days.
I didn't drill out and retap the holes though. I used metric grade 8 for the x-member side and 1/2 grade 8 for the control arm side. You will need to open up the hole a little on the control arm as the 12mm bolt hole is just a tad to small for the 1/2 bolt.
09-02-2010, 09:20 PM
So I didn't get to much accomplished today. I finished off the front body wring harness. The mailman brought me a gift today so I was actually able to install the harness. When I removed the harness I cut all of the old zip ties holding it to the frame. I had to order new ones and it took some time to hunt down. I finally found some that would work from a company called clipsandfasteners.com.
Push Mount Cable Tie For Imports 200mm Length
They hold pretty good in the think metal like the side frame by the wheels. Thinner metal they pop out if to much stress is applied. They are still the best fasteners I could find. After getting the harness attached I noticed the main power wire from the engine fuse box had oxidation pretty bad so I have to pick up some good power wire to replace the corroded one.
Tomorrow I am going to try and remove the front steering rack so I can finish removing the AWS lines and plug up the holes. I may replace it with the N/A rack I have depending on it's condition.
Once that is complete I need to start prepping the engine for removal from the other car and start pulling the interior as I need to wire in the new gauges and electronics into the new car.
