Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 69
Thread: DIY 94-97 to 98-99 Patch Harness Parts
    You guys are right about buying these connects in bulk quantity but here are two sites that has the male connector in stock.
    Male ECU connector:
    1. Master Distributors - Over 300,000 Electronic Components In Stock! (requires $35 purchase)
    2. Electronic Component Distributor | Onlinecomponents.com (requires $35 purchase)
    Engineering Nerd verified
    Mainz, Germany
    FYI this is one of the harnesses I built:
    This one is Gen1 only, hence the missing plug. The last one I built was Gen1 and Gen2-Hybrid.
    All the important sensor wires are coded in colors mostly compatible to the colors used on Apexi S-AFC and AVC-R the rest is white.
    As you can see I did't cast the male housing in epoxy like boomslang does. I failed at making a mold and found it's not really nessecary as long as you don't pull hard on the wires. Everything is insulated with shrink-tubing instead with alle the sensors wires having additional pieces of unshrunk shrink-tubing for convinience.
    August 2010
    Chicago
    Is anyone going to be doing a write up on this anytime soon??...
    I have a writeup in the works myself, I just have to finish the job before I post it..lol
    Hey your write up will be huge contribution to making the conversion harness more available to the diy crowd.
    Mainz, Germany
    Whats there to write up? Get the parts, get some wire, cut it in pieces, solder one end to the recaptable, isolate with shrink tubing, crimp a connector to the other, put connector into plug housing, repeat for all other terminals.
    If you're asking what wire to put on which terminal for an ECU swap, I can't help you with that. All I've ever done was straight through adapters to hook up piggy-back units to.
    But you can find the ECU terminal lists for all models on stealth316.com this should be enough.
    San Francisco
    Awesome thread. I'm doing this to run my 94 ECU in my 92 wiring harness. This gives me all the missing info I needed!
    Mainz, Germany
    Everyone who wants to swap ECU's between 2-bolt and 4-block engines with the different CAS need to read this:
    Jeff Lucius on CAS conversion
    just a reminder that doing the wiring is not the only job when you're swapping ECU's...
    Charles Town, WV
    I'm not sure that there is more than a couple 98/99s out there, and I'm not sure the non-3S ECUs will be sold as a modified ECU without the adapter harness. But, this is still good info, especially for making your own pass-through harness.
    1995 VR4 Coupe
    I understand that there are a few 98/99 ECU's to grab from but right now you can get a 98/99 ECU for $726 off of trademotion. If you compare the cost of getting an Emanage Ultimate, ACR2, and AEM, buying a new ECU is not that expensive.
    Mainz, Germany
    Also when you want to go fully programmable and make it plug&play on the OEM harness. There may be the day that you want to put the OEM ECU back in the car and then a hacked up harness will be seriously annoying.
