This is on a DSM so I thought I'd post it here, but the question is a general question, though the situation pertains to my DSM so...anyway...
I'm installing a new exhaust header on the car, but it's being a bit difficult, if you look at the head where the exhaust ports are in relation to the turbos location, it's angled, I'd say like 65ish degrees and with the new headers, it's like a 70ish degree, so it's not fitting snuggly enough to bolt up, my question is, can you loosen the Vband on the turbo and rotate the exhaust side a little so that it matches up, without ruining anything or causing any problems, it seems like the hardlines are going to get a little tweaked if I just bolt it in and use the bolts torque to pull it up into its place.
I know this makes it sound kind of like it's way off, but it's really not, with the headers bolted to the head, I'm able to get the two front bolts started on the exhaust housing, but at the rear, there's maybe an 1/8th inch gap and I can't get the bolts started because of the angle and it doesn't seem to want to wiggle its way in place.
This idea just had crossed my mind and I've never disassembled a turbo before so I was wondering if it were at all possible, tomorrows attempt is going to be fully disconnecting all lines and bolting it up then trying to fish the lines in and get them installed I guess...
After proof reading...did any of this even make any sense to anyone other than myself? ha
