Results 21 to 30 of 31
Thread: 91 R/T won't shift
    if it only happens ~60mph or higher, it's not loose lugs. you'd notice that at 5mph.
    stow
    its got be out of balance , how old are the tires? i have had a lot of tires when they get mileage start to vibrate at speed, warped rotors is a old wives tale
    "warped rotors" is bullcrap. they might be heat-treated due to excessive braking; but that would only produce vibration during stops--not at speed.
  4. #24
    Rotors can be warped by overtightening the wheels. That is fact. The warped rotor by excessive braking is the wives tale.
    And my comment about overtightening is a seperate comment from his vibration issue. I just noted its bad.
  5. #25
    Oct 2010
    Chicago-South burbs
    I don't know how old the tires are. The tread is awesome on all four. However, as I mentioned earlier I have a hound from every town! They are all the same size and I checked to see if any weights had popped off and all is good. I hate the R/T wheels! My wife wants me to hold off on putting new tires on my R/T TT wheels until spring. So, I guess I will just have them balanced to make sure.
    It only vibrates at 60+mph...so my guess is the wheels/tires out of balance or a broken belt.
  6. #26
    St. Charles, IL USA
    Make sure to change the caps in the working TCU if they are original or it won't be a working TCU for long.
    Unlike the ECUs, when the 47uf cap by the voltage regulator pass transistor leaks there is a very good chance the regulator will fail and dump 12v on the 5v buss to all the chips blowing them.
  7. #27
    ^is the the genius whose advice i've been warned about?
  8. #28
    No, the Steve you've been warned about is Steve68.
  9. #29
    Oct 2010
    Chicago-South burbs
    Yeah I plan on having the third tcu rebuilt after I get my other two back. The original one was in such bad repair no way a novice like me could ever touch it and reserect it.
  10. #30
    St. Charles, IL USA
    I think you have me confused with someone else.
    They're not normally repairable once they've failed.
    I wouldn't say normally not repairable. I have fixed many of them but the odds are bad enough that I won't anymore.
