sweet
Well, I was not on target haha. I'm still running into interference between the bluetooth and keyfob bands. The keyfob module just won't work near the bluetooth module. Works perfect if I move bluetooth 4-5ft away. I really need to talk to a rf engineer on this one. I've tried to do some reading and man...it's complex stuff. Hard to find simple answers.
Anyone have any experience in this field?
2013 January Car of the Month - All 3s
2011 November Car of the Month - Interior
If my links/photos don't work replace penguinhosting.net/~bigmac with primaryboost.com
Uncut 3000GT keys for sale! Various colors!
Can you provide a block diagram of your system? I've been engineering RF products and systems for 25 years.
Outline of what I have going on.
Some links
rn-41 bluetooth->serial module
http://www.rovingnetworks.com/documents/RN-41.pdf
433mhz keyfob module (Their site is down but their ebay store has some info)
Rolling Code RF Superheterodyne RX Module&Remote/Keyfob | eBay
I've tried isolating them by powering one off battery. It really came down to the distance away so I don't think it's a decoupling issue.
The keyfob is using on/off keying. The 433 MHz receiver module is probably using a simple filter and an envelope detector to convert the RF pulses back to digital signals. This kind of receiver is not very immune to interference.
The bluetooth module is operating in the 2.4 GHz ISM unlicensed band and uses frequency shift keying. There may be unwanted emissions coming from the bluetooth module in lower frequency bands depending on how the final RF frequency is generated.
An invaluable tool for determining what is happening is an RF spectrum analyzer. If you could borrow one you could attach an open ended coax cable and use it as a "sniffer." You would be able to place the bluetooth module near the spectrum analyzer and see what RF frequencies and levels are being generated. IF you found energy near 400 MHz then you could take steps to filter it out on board prior to the bluetooth antenna element.
If you are unable to make changes to the bluetooth module you could try alternative vendors to find one that is compatible with the keyfob device. Unfortunately I don't think you will find keyfob devices with better interference immunity as they are not expected to coexist with other transceivers.
Hope this helps
Jim
Well I did some light reading on different modulation types for some background and started searching around. I was actually able to find a keyfob and receiver module that allowed me to use both it and bluetooth to over 130ft! I'll have to do a few modifications for my application but it looks like it will actually work out. I'm pretty excited. Can't wait to fire up the cnc and mill out the board![]()
subscribed![]()
91 AWD TT
So I've gotten deeper into all of this rf stuff...
The new fob and receiver I was using left me with a few limitations. I was stuck monitoring multiple input lines to detect what button was pushed on the receiver. I also had to debounce them and try to figure out if buttons were double clicked etc. This is not ideal as I could miss events. There were too many delays etc.
I wanted to modify the firmware on the fob and receiver but unfortunately this was not easy. First the transmitter was an RF transceiver and MCU combo that was not modifiable. I'd have to replace it and buy new burning hardware from the company.
This basically led me to a direction I should have gone in the first place. Roll my own rf fob and receiver hardware. The new fob/receiver module was from Silicon Labs and used their new EZRadio chips. I liked the features and found a tuned breakout board with one of their rf transceivers.
So now I'm using the si4432 on a hope electronics 434mhz tuned breakout RFM22. I am amazed at how powerful this chip is as far as function goes. I'll be able to use the fobs from the kit I bought so I'll just come up with my own board. This chip allows me to set the modulation I want to use and add any encodings etc.
Now I'm working on the uC firmware to control it. My plan is to use an Atmel attiny24 on the fob side and the atmega328 I have on the receiver/controller will handle receiving.
I have two circuits talking to each other so now I'm just going to work out the details.
