Results 1 to 7 of 7
Thread: Frickin car wont start, little help please
    So I pulled the car out the other day to turn it around and work on the body on the other side. Pulled it out fine started backing it in and I had some ugly shuttering and it had a huge backfire and died. And hasn't started since.
    I pulled the plugs out and they were obviously fouled from the experience. So I replaced all of them. I tried to start the car up today and notta. I'm getting fuel since the plugs are wet, its cranking fine and the ECU light does turn off after a couple seconds of cranking.
    Any suggestions would be wonderful.
    Iceeagle2102 on that "other" website
    Think i got it. Checked the resistance in the secondary coils and way lower than it should be i.e. 1000ohms not the 13-16k. The primary however looks good. Guess its time for a new coil pack.
    G
    Are you not getting spark?
    Nope, Plugs are wet but nothing. Checked the timing belt and everything is lined up so thats not an issue either. CAS was replaced when i changed the timing belt so that wouldn't be it. With the resistance readings im getting i think the 18yr old coils may be done for haha.
    Before you buy a coil pack test your PTU.
    Stealth 316 - Power Transistor Unit
    I was planning on it but either way it shouldn't have any affect on the coil resistance which is obviously off.
    I'll stop acting like I know shit now. LOL.
    I've been down the road of buying the wrong parts blah blah.
    Just a lil heads up
