Results 1 to 10 of 20
Thread: Corbeau Seat Installations anyone having/had my problems?
    Corbeau Seat Rails + Brackets*-*Mitsubishi 3000GT*/*Dodge Stealth Parts
    Anyone had any problems mounting these seat Rails? the tabs that you bolt through don't line up and the inner seatbelt side actually appears to need to be shimmed up!!
    anyone?
    1996 GTO, Owner since 2003.
    I modified a 1g dsm rail to fit in my car
    -Benn
    Master Elite KIA Technician
    Follow my build thread here
    yeahh with much stuffing around I've made them fit :| funny enough they are only just able to move forward enough for my feet to fit on the pedals
    looks like alot of people have the same problems doing a fair amount of digging around google. :|
    Most people have to ream the bolt holes out by all accounts.
    im looking at the fx1 pro right now and thinking about getting it. how tall are you? im 5'8 and if my feet dont reach the pedals ill be pissed... also to fit the rails drill out the holes to be bigger??? thats all it needs to fit?
    06 Mazda6s - Gone
    02 Subaru Impreza WRX - Sold
    95 Subaru Impreza USDM WRX engine JDM STi exterior swap - Sold
    05 Dodge SRT-4 - Sold
    94 Dodge Stealth RT turbo - 99 front end, 13G's with supporting bolt ons
    FS: 1)Spec stage5 clutch kit $150 shipped 2)Stealth RT LED taillights $80 shipped 3)Stealth pearl yellow OEM 17's with tires 4)RARE Defi narrowband airfuel gauge $70 shipped 5)DNP Y-pipe with Blitz DD BOV $220 shipped
    I'm what...175cm? and yeah just had to drill the holes AND the rear rail does not sit on the holes level so I had to shim it up to make it level (the rear bolt tunnel side on both sides was over 1" lower than where the mount was attempting to attach to.
    I think I'm also going to put another metal bar on the rails so I can have the seat further forward normally AND so I can lift the front of the seat up.
    Advanced Tech? verified
    i used to have the FX1's. do NOT use the bottom mounts, use side mounts so you can tilt the seat. if you use the bottom mounts, the seat is just way too "flat" and you can't adjust the angle. you will feel like your butt is sliding forward all the time. also, you will feel like you're slouching all the time because the seat is bolt upright.
    GENERAL corbeau bracket top tip:
    when bolting it down (after you've widened the hole), if you notice that there is a gap between the bracket and bolt hole, do NOT just crank it down. doing so will bend the bracket, and the slider with it. it will be very difficult to adjust. use a solid spacer of some sort (not a stack of washers).
    bottom mounts? side mounts? picture of what your talking about?
    corbeau seat and sparco side mounts:
    corbeau side mounts:
    for the lowest possible configuration (e.g. helmet space), i recommend ditching the sliders completely. drill and bolt the side mounts directly to the bracket. mount the seat using the lowest holes in the rear, and give yourself a little tilt in the front.
    of course, your girlfriend and midgets won't be able to drive your car, but oh well.
    oh wow shit, my seats did not have that option....damn I wish.
