I had posted this on the "other" forum and figured I would share it here as well.
So, I started trimming some major fat on my 91 Stealth. This is a list of things that I have already done. Keep in mind though that some of the items will be replaced with lighter wieght aftermarket parts so of course you will be gaining some of the wieght back. Some of the things I have listed are pretty drastic.
Here it goes:
Airbag ~ 4 pounds
Diver Seat (57 pounds) swapped for Corbeau Forza Seat/bracket (29 pounds) ~ 28 pounds savings
Passenger Seat ~ 44 pounds
Rear seat with both back rests ~ 26 pounds
Complete AC system ~ 29 pounds
Rear wiper assem. and washer fluid reservoir(full) ~ 9 pounds
Complete Audio (double DIN head unit, speakers, power antenna) ~ 18 pounds
Complete interior minus the dash (headliner, all molding, door cards) ~ 38 pounds
Sound deadening material ~ 15 pounds (removed from bottom of trunk, directly under front seats and rear seats, rear wheel wells)
Empty Fuel Tank (33 pounds) swapped for 4 Gallon Fuel Cell (7 pounds) ~ 26 pounds savings
Entire Dash (minus the gauges) ~ 30 pounds
Blower (under the dash) ~ 6 pounds
AC Cooling Unit (under the dash) ~ 8 pounds
Heater Unit ~ 8 pounds
Rear Crash Bar ~ 38 pounds
Random Interior Junk (plastic, weather stripping, etc) ~ 28 pounds
Extra Floor Pans (at feet of front driver/passenger) ~ 11 pounds
Sail panels ~ 8 pounds
Sail panel windows (replaced with sheet metal) ~ 8 pounds
Weather stripping guides around doors ~ 4 pounds
Fidanza Lightweight Flywheel ~ 9 pounds (difference between this and stock flywheel)
Stripped Unused Wiring ~ 10 pounds (so far, still have two harnesses to go through)
Total Weight Savings ~ 405 pounds
Some of these items you may be asking if it is really worth it to remove...that my friend is up to you. For me, this will be a track only car and they are items that I will not need that together add up to a good amount of wieght.
One last good weight saving item....yourself! If you are 30 pounds over weight......which is the case for a lot of americans....do what it takes to lose that weight. Not only will you be helping with your car...but you will be healthier as well!!!
