Results 1 to 10 of 26
Thread: New Redline MT-85
    New Redline MT-85
    Redline MT-85 75W85 GL-4. Anyone on here running this? Essentially this should be the same as mixing MT-90 with MTL (I have heard both 50/50 and 70/30). Just curious as to how you liked it, any complaints etc...
    Secret Lurker Man! verified Feedback Score 2 (100%)
    7/10/06 or somethin
    Bend, Oregon
    I believe they finally decided to make an 85 for the EVO and others that required a 50/50 mix, it should be just as good if not better than the mix, I think it's too new for anyone to actually have been running it long enough to give decent a review on though.....go get some and let us know! ha
    It's too new for anyone to have really been running it long enough for now. I still have a box of MTL and MT90 in the garage, but I might buy MT85 and try that after I'm done break in. I have a feeling it's going to be pretty sweet
    Feedback Score 6 (100%)
    Im sure it will work well. I have ran straight mtl with very good results in the past.
    Sent from my DROIDX using Tapatalk
    I gotta get off my ass so I can get my "to do " list done. Gotta fix that driveway first...ugh.
    SDSU Alumnus verified Feedback Score 4 (100%) bboyalan's Avatar
    Nov 2006
    Chula Vista SD, CA
    Yes! I did a drivetrain fluid change last month, and it was much more convenient than my required mixing in the past. I have done the 50/50 and 40/60 previously.
  7. The Following 2 Users Say Thank You to bboyalan For This Useful Post:
  8. #7
    I had good results with straight MT90, until it got cold. Swapped to the mix in the VR4, and it was golden.
    edit: didn't reload before I posted. Nice to see someone using MT85
  9. #8
    Been using Castrol VMX-M...4L is ~$41 seems to work just fine
    1996 GTO, Owner since 2003.
  10. #9
    Elko, Nevada, United States
    I'm running MT85 in my drivetrain, and it has VASTLY improved my shifting and all around feel of my transmission. Needless to say, I had some generic shitty ass GL-4 in there before, but shifting was very notchy and required some decent force to get into 1st. Since I switched to all Redline fluids in my drivetrain, everything has been much smoother and more enjoyable to drive. I haven't put a ton of miles on it yet, but I noticed a difference in shifting the moment I drove it home from the shop.
  11. #10
    Bringing this back up from the dead.
    The NP driveline package-
    I'll be swapping this in when I do the 60K. Scared of what the PO has in there.
