Page 1 of 9 123 ... LastLast
Results 1 to 10 of 85
Thread: How do you do the ABS delete?
    Pueblo, CO
    Im thinking more and more about deleting my ABS and was wondering if there is a right up somewhere how to do this? I looked on stelath316 too and serached here and couldnt find anything. Anyone know or have a link? How much weight do you save doing this?
    you can either by the stock non abs proportioning valve and the stock lines, bend your own lines, or go with STM's kit. I went with STM's kit because I thought it would be a nightmare to get the hardlines in with the engine in place.
    No complaints so far, other than I need to do some more bleeding.
    I can weight the abs pump, but it was actually a bit lighter than I hoped, I think it is only 12 or 13 lbs. I have to pull the rear panel and get the abs computer out too, that should be another 2 or 3 lbs. 20 lbs at absolute best, but I think closer to 15. It does clean the engine bay up quite a bit around the battery and air filter area.
    Pueblo, CO
    Forest, can I see what your bay looks like now with the lines out?
    sure, I'll try to snap a pic tonight.
    Secret Lurker Man! verified
    7/10/06 or somethin
    Bend, Oregon
    Using the stock parts is the cheapest, use a non abs prop valve (located on firewall) the lines from the prop valve to rear wheels are all the same, just the fronts are different, so you remove everything except rear lines back...part numbers are:
    ABS Delete:
    OEM ABS Delete Parts for reference:
    MB618846 x1ea - Line from MS to PV
    MB618849 x1ea - Line from MS to PV
    MB618840 x1ea - Line from PV to RH
    MB618843 x1ea - Line from PV to LH
    MB668841 x1ea - Non- ABS Proportioning Valve
    Copy and pasted from an ABS delete I've got saved on my comp I'd go with stock parts, for one, the price is unbeatable, the lines are like 4 bucks a piece, the prop valve can be had from a parted out car with non abs for like 20 bucks, so you can get the parts for less than 50 bucks
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Can those lines still be purchased new? I thought they were discontinued?
    one or 2 of the master cylinder line's are discontinued. You can still get the left and right lines.
    You also have to pull the steering rack to install some of them. no thanks.
    ~2006
    I'm just not real big on having that much flexible line when I could replace with hardline but it would be a PITA. I wonder if having the trans/turbos out would help any as they will be out in the future. Engine hopefully not for a while lol!
    sure I'm with you. I have the left and right stock non abs lines on the shelf for the day when my engine blows. I don't have the patience to try to snake the hardline in with the engine in place, so this will work for now.
  • History
  • Information
  • Groups
  • Events
  • Resources
