I just wanted to follow-up for anyone else looking in the future. I always try to.
I finally found a cost efficient belt tension gauge online and its actually a pretty neat lil device and much cheaper than the over $100 belt tension gauges I've seen that the pro shops probably use.
It can be found online in various places (Amazon and Ebay), but I found it at NAPA Auto Parts for around $13. The NAPA part numbers for the belt tension gauges are:
NBH KR1
NBH KR2
Elsewhere I have seen them as:
Krikit V-Belt Tension Gauge (91107) by Gates
Gates 91132 Belt Tension Tester by Gates
Each of the 2 gauges handles a different range of tension. Since they are so inexpensive, if you are doing a lot of routine maintenance work on various cars you may own, I think having both gauges in your tool box is a good idea and it would probably eliminate the trial and error guess work method of getting the belt tensioned properly by cranking the engine on and off between adjustments.
It seems that these lil gadgets "sense", by pushing downward on the belt, when to "click" a little clicker in the gauge and as soon as you hear that click you stop pushing and read the tension. Pretty easy.
I have yet to experiment with it, but when I do I'm sure it'll be helpful. Hopefully I'll post back and let ya'll know how it worked out.
