This is one of the few in existence that I helped design back in the day.
Bottom is CNC machined to perfection, top section is 6061 aluminum welded on.
Accepts stock throttle body.
The radiator fill must be capped off and an inline fill must be added to the top radiator line. I will supply these two parts as well.
I have a custom made short y-pipe made with the CNC machined y-block used in the $300 AAM y-pipes that I will also include, that fits with the stock IC pipes.
If running a FMIC then you could cut the end off this y-pipe and use the existing block by just welding on a 3" piece to fit.
I will also include a new intake manifold gasket and the mounting bolts for the manifold.
Follows are pics of the other two we did on the cars. This particular one I have was an improved design which was approximately one to two inches wider, everything else is the same.
I will post of pics of it shortly.
$700 shipped with everything.
). It was really nice, I wanted one.
