Originally Posted by
deemo99
No gasket for oil pan, I use the Mitsu recommended stuff (purchased from 3SX with my new pan), but I am sure there are comparable products that will accomplish a seal as well. Careful removing the pan. It is super easy to end up with a very wavy sealing surface from removal by wedging between the pan and block, even with the factory tools. You can also damage the drain if you pull from it as well. I replaced my pan so I don't have a method that doesn't distort or damage it at least a little, sorry. I am sure it has been covered by others.....
