Results 1 to 3 of 3
Thread: Question about pluggin the hole in upper intake manifold...
    Rancho Cucamonga, CA
    ...just like it sounds. Because it's late and I don't want to measure it (shame on me) what size plug should I order to plug the rear opening in the upper intake manny for where the brake booster or whatever the shiz that is? I'm about to do the clutch booster delete (that's where one of my boost leaks are) and just want to know the plug i need to order so that I can knock it out quick status.
    I am going to snag a 1/8" bspt plug as well as a temp sensor adapter for my water temp gauge to toss it in the coolant line but would love to knock this out at the same time.
    Thanks in advance, guys, and if this doesn't make enough sense I will clarify it tomorrow when I'm fresh and sober.
    and a 95 too! Feedback Score 0 deemo99's Avatar
    April 2005
    Door Peninsula
    I did a cluth boost delete, but tied the clutch booster into the brake booster, both of which need a vacuum source. There is also a check valve you'll need to re-use so you don't supply boost.
    I can take pics later, car is not available at the moment.....
    1995 3000GT VR-4, 1 of 6 identical
    DR-16Ts, ARC2, 550s, supra pump, GReddy FMIC, Tomei BOV, RPS max full face, 3SX fuel rail loop, AEM wideband boost & oil pressure in stock location, Stillen DP, gutted rear pre-cat, Tanabe Touring Medallion catback, HHH datalogger, active aero sim w/3SX splitter, vac redux, Tein S KYB GR-2, Maximal control arms, 3SX poly bushings, ss brake lines, IPS rotors carbotech pads, ABS delete HKS EVC 6, HKS DLI, Maximal powder coat, 5hp chrome twin turbo plate, BSLCDBC
    1999 3000GT VR-4, 1 of 65 identical
    Jack-stand mod for now.
    it's probably fair to say that I've seen more cranks than a lot of other people on here.
    April 2005
    Door Peninsula
    Nothing fancy here, but it gets the job done. Just need one 90 degree fitting, one tee fitting and a short section of hose. Make sure you put the check valve in the line, I reused one of the factory ones. Kinda hard to see in pic, but by the IC pipe runs to the mani, check falve before the tee fitting, rest is easy.
