Just wanted to post my personal experience with Amsoil MTG. Previously I was using synchromesh and what I found is that it would always give me the same performance cold or warm, would grind if you tried to force it into gear. However, cold and warm shifting was fine if you took it easy.
after switching to amsoil last year, i've found that warm performance is much better. Cold is still the same, need to ease it into gear or it will grind. After driving about a half mile or so and it warms up, shifting gets a lot softer. after the engine and transmission are at full temps, all you feel is slight resistance when you shift, and then it just drops right in. High RPM upshifts and downshifts are no problem, you can shove it into gear like a honda and not have to think about it.
Good info. Considering Amsoil for the trans in my DSM.
