Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Re-visiting Oils
    Re-visiting Oils
    well, since I'm going through another breakin on the car oil wise I figure I'd look at what's around and what's available at a REASONABLE price...
    so I've settled on some fairly widely available oils..
    For the Gearbox/TC: Castrol VMX-M...$42 (4L)
    http://www.supercheapauto.com.au/onl...126527#details
    For the Engine: HPR5 $44 (5L)
    http://www.supercheapauto.com.au/onl...=14911#details
    For Kaaz Rear Diff: Penrite Limslip 85w-140 (2.5L) $25
    http://www.sparesplanet.com.au/gener...0-2-5-ltr.html
    will let you guys know how it all goes.
    Stuff I'm also testing is:
    EBC Yellowstuff pads (the level above Redstuff, which have been excellent)
    RBF600 Brake Fluid (very good without the $10 premium per bottle the RBF660 carries)
    For an Oil Flush I use the Penrite Everyday 5w-40
    For Filters I just use Ryco's
    1996 GTO, Owner since 2003.
    Melbourne, Australia
    How long are you going to be running these oils? cus I wouldn't use Penrite in my car for even 5 mins. Penrite HPR series is way over priced for the crap it is. Your better off with a cheap Castrol semi synthetic.
    Waiting install
    Build Thread
    what would you recommend specifically for the engine then? I've been using Sin 5 but it's $80...?
    I spoke to Harold at performancelub.com and he suggested if you can't afford Redline then try the Royal Purple or Amsoil oils. Personally I am using Castrol Edge Racing 10W60 [$75] but I will be using Amsoil or Redline on my next change. Harold also stated the Castrol is only a middle range product but it's better than the others in that catagory. [Also better than the Penrite stuff]
    well, I'll let you know how I go on the cheap stuff
    stow
    if i was to break in another engine i would look at the new break in oils availble, and for a oil filter i would use the royal purple filter. i was in summit racing a few days ago and they have a comp cam break in oil and also royal purple break in oil made with more zddp just for break in. they also have zddp to add to the oil. . it may be overkill but probably worth the cost.
    not breaking in the engine...just the GB and Diff.
    Are you using the HPR5 for a flush or are you planning on running it for the full term. Just it's only a semi synthetic. No matter what brand I wouldn;t using anyhting except fully synthetic.
    not far from breaking down
    Mike with the amount of money you have invested into your drivetrain, whatever you do make sure you do it properly dude. Would kill for a drivetrain like yours
    Maddy
    I'm pretty sure even the shittiest oil will be "OK" and yes I'm using it long term, I'm flushing with something worth $20...maybe after I build the other engine I'll start really wasting money on oil. I'll be putting decent oil in the drivetrain though.
