Results 21 to 30 of 34
Thread: Tips for install
    I Kill Threads verified
    Wichita KS
    I was able to get it off, but couldn't get the new one back in because there are studs in the new one so there's not enough room to maneuver.
    Did get the injectors in and they don't appear to leak. Gonna to go a shop tomorrow to get the studs out and finish the front then start the rear.
    1992 3000GT VR-4
    Wichita KS
    While the front is at the shop I started working on the rear and the manifold bolts came out easily, but now I'm stuck on the oil feed line. I sprayed it with WD-40 and it's been sitting for about an hour so I'll give it more time, but do I turn the big bottom nut while holding the hardline small bolt in place, or vice versa?
    Hold the bottom big nut, and loosen the top small nut. Does the new turbo have that adapter already? Either way, you need to get the small nut loose, and the line off before you remove the adapter, or you'll twist the feed line.
    Wichita KS
    Alright thanks Doc. The new one doesn't have an adapter but thats the one thats turning easily so it'll come off once the small nut and line is off. Just gotta sit around and wait for that WD-40 to work.
  5. #25
    Ok, it may be a bit tough to break free, mine was a PITA too.
  6. #26
    Wichita KS
    I just got back from picking up the turbo and downpipe. Good news is the turbo is in! Just bolted it to the manifold for now as I have to go to work soon, but I also tried to undo the rear oil feed line and couldn't get it. Also I had them weld the wideband bung on the wrong side of the downpipe Welded it to the left side and it looks like it needs to go on the right.
  7. #27
    Wichita KS
    Ok first day of not working and I nearly completed everything. I would have been done hours ago except for I think putting a throttle body bolt in the plenum and it breaking.
    I've got 4 bolts left and any of the four will go into three of the throttle body holes, but none will fit in the bottom front throttle body hole. It feels like that hole on the plenum is smaller then the other 3. Of the bolts remaining, two have 4 on the top, and two have 7. The broken bolt is a 4 also.
    What's up with the throttle body bolts not fitting and how do I get that broken bolt out?
  8. #28
    Formerly OwnGTP/WantRTTT
    April 2004
    Houston, TX
    You're going to need an easy out extractor to get the broken bolt out.
    As for the TB bolts, they should all be the same size and all be grade 7 if memory serves me right.
    Tony M.
    2002 Jeep Grand Cherokee Overland - There's Only One.
    1995 Dodge Stealth R/T Turbo - Gone but not forgotten . . .
    “The danger to America is not Barack Obama but a citizenry capable of entrusting a man like him with the presidency. It will be easier to limit and undo the follies of an Obama presidency than to restore the necessary common sense and good judgment to a depraved electorate willing to have such a man for their president. The problem is much deeper and far more serious than Mr. Obama, who is a mere symptom of what ails us. Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. The republic can survive a Barack Obama, who is, after all, merely a fool. It is less likely to survive a multitude of fools such as those who made him their president.” -- Author Unknown
  9. #29
    Yep, all of the bolts to mount the TB are the same size, and all the same grade (7 maybe, I don't remember)
  10. #30
    Wichita KS
    Ok so do the grade 4s go in the plenum then?
    I'll go pick up an easy out, buy with the bolt most of the way down the hole do you think it'll work?
