Results 11 to 20 of 34
Thread: Tips for install
    I Kill Threads verified
    Wichita KS
    Thanks for the tips guys, I'll be starting soon. Hopefully will finish before midnight tonight!
    1992 3000GT VR-4
    Wichita KS
    Ok another question, is the walbro install kit necessary or optional? It looks like it's just some wires. I got the pump for free and never thought about having to get something more to install it.
    Edit: Upon looking it seems like it is necessary, now the question is are the kits interchangeable? We require an 800-857 but looking on ebay the kits are listed as exchangeable and all look the same. A local shop has an 800-847 that is used on 2g dsm's and evo's, so would that work?
    Newark, DE
    The kits are good for plug connections to walbro. They r cheap IIRC. I got my pump & kit from STM, site sponsor; send Austin a pm or order from their website.
    Wichita KS
    I just emailed walbro to find out if the 800-857 and 800-847 are interchangeable so I'll hope to find out by the end of the day.
    My injectors didn't come in the mail as scheduled so I'm putting off installing everything til tomorrow so I can do it all at once.
    Formerly OwnGTP/WantRTTT
    April 2004
    Houston, TX
    For the injectors, make sure you have some new viton O-rings on hand if the injectors don't have new ones already on them, those bitches tear real easy when pulling out the old injectors and aren't reusable when they're messed up.
    Also, when seating the injectors and rails back down, make sure the rubber isolators in the lower manifold seat right. I had one get jammed in crooked and didn't realize it, after a few heat ups and cool downs the rubber hardened and cracked causing a huge vac leak and the car ran like shit.
    DR-650s should be cake since they're TD04. Just make sure you put something there to protect your radiator or you'll curse yourself for putting a hole in it.
    Happy hunting.
    Tony M.
    2002 Jeep Grand Cherokee Overland - There's Only One.
    1995 Dodge Stealth R/T Turbo - Gone but not forgotten . . .
    “The danger to America is not Barack Obama but a citizenry capable of entrusting a man like him with the presidency. It will be easier to limit and undo the follies of an Obama presidency than to restore the necessary common sense and good judgment to a depraved electorate willing to have such a man for their president. The problem is much deeper and far more serious than Mr. Obama, who is a mere symptom of what ails us. Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. The republic can survive a Barack Obama, who is, after all, merely a fool. It is less likely to survive a multitude of fools such as those who made him their president.” -- Author Unknown
    Wichita KS
    I just got the injectors today and the o-rings looked good, I'll look over them again to make sure though. They're the thing I'm most scared about, I tried to help a friend put a new fuel rail on his pontiac GTO a while ago and the things just wouldn't go in right, kept leaking and leaking.
    I think the front turbo will be the easiest thing because I don't have the downpipe on, I'm just gonna unbolt the wastegate and turbo from the manifold and pull everything straight up. In fact gonna go start now that I've got everything.
    Wichita KS
    Fuel pumps in, easy thing to do but I had to use some foam to mount it properly. Runs though and doesn't leak.
  8. #18
    XLR8TOR
    Las Vegas, NV
    APR Ultra-Torque Lubricant is great for exhaust/turbo bolts because it has all the requirements for torquing plus high pressure additives and anti-sieze built right in. It's awesome stuff.
    Can also be used on plugs but be very careful to NOT over torque, especially on any bolts that go into aluminum. Check your torque specks first.
  9. #19
    Wichita KS
    Alright this front turbo is harder to take out then I imagined. How do you get to the oil return line on it? If anyone knows of a guide that be helpful.
  10. #20
    Unbolt the return line from the pan and remove it as one piece.
    I used this guide, IIRC http://stealth316.com/2-tsg_v10.htm
