Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Tips for install
    I Kill Threads verified
    Wichita KS
    Tips for install
    I just got some DR650's and plan on installing them tomorrow. I'm also going to put 550's in and a walbro, as well as hook up an emanage blue.
    Does anyone have any tips for doing all of this? I'm gonna use the guides on stealth316 but any further knowledge would be good.
    1992 3000GT VR-4
    Use brand new bolts and anti-seize on the turbo bolts. Personally, I'd budget two days on all of that, just because of the tedious work involved, and the possibility of having to remove seized in stuff. Turbos should be doable in 6-8 hours assuming it all goes well, 550's should be doable in about an hour and a half, and the Walbro shouldn't take too long either, assuming the tank studs don't need rebuilt. If the emanage is all ready to plug right in, that's cake.
    Wichita KS
    I think the emanage is ready to go, I'll have to go over the wiring thats already in it and check beforehand, I'm scared of cutting the wrong things for that though.
    On stealth316 he says the injectors take about 4-6 hours and I'm not finding a turbo guide, but that seems pretty straightforward. I can take as long as I need now that I'm done with classes for the semester, so time won't be an issue. Good idea on the anti seize, I hope the stuff isn't already seized up, but thats what air guns are for
    I've already had my downpipe off for a while now so that'll cut down the time a bit. Any other tidbits from anyone?
    Player Hater of the Year
    San Antonio, TX
    Just like usual, dont drop stuff in the lower intake when removing the upper. Take your time on the rest, do it right the first time!
    (Off topic to Steven below me: Steven! What up!?!)
    Colin!!!!!!!!!!!
    Sorry, I had nothing to add to this thread, just wanted to say hi.
    Dude, 4-6 hours for the injectors if you're taking a break constantly, lol. Having it all off at once makes it super easy to just do everything at once. The turbos have a few specific tricks, like the rear pre-cat heatshield needs rotated to the right, and pulled up really f'ing hard. Air tools may not help with the bolts, that's what I was using the second time, and the threads on the bolt cammed in and refused to pull out, so I had to drill it out. Twice.
    Wichita KS
    Ooh that sucks doc. I figure that estimate for the injectors was a lot longer then it really takes, and I may be wrong but I dont think I have a rear heat shield to worry about.
    If you don't have one, that makes the rear turbo job SUPER easy. Probably one of the easiest "big" jobs I've ever done. Everyone was bitching about the rear being so difficult. The only hard part was the heatshields.
    and a 95 too!
    April 2005
    Door Peninsula
    New gaskets for TB, Lower Intake etc unless they are really new. Re the fuel pump, get your PB Blaster or equiv on there ahead of time. I now have 5 of 6 studs on the tank with no issues, but I know it's that way and that's enough to drive me nuts Rear heatshields should be the biggest PITA depending on fastener condition. I like to pull the radiator to do the front turbo, just way more room and no accidental holes in the radiator, but that's just me. Not sure if DR650's are the same, but I had to grind down the front motor mount a little for the 16t's to fit.
    1995 3000GT VR-4, 1 of 6 identical
    DR-16Ts, ARC2, 550s, supra pump, GReddy FMIC, Tomei BOV, RPS max full face, 3SX fuel rail loop, AEM wideband boost & oil pressure in stock location, Stillen DP, gutted rear pre-cat, Tanabe Touring Medallion catback, HHH datalogger, active aero sim w/3SX splitter, vac redux, Tein S KYB GR-2, Maximal control arms, 3SX poly bushings, ss brake lines, IPS rotors carbotech pads, ABS delete HKS EVC 6, HKS DLI, Maximal powder coat, 5hp chrome twin turbo plate, BSLCDBC
    1999 3000GT VR-4, 1 of 65 identical
    Jack-stand mod for now.
    it's probably fair to say that I've seen more cranks than a lot of other people on here.
    Newark, DE
    Recently installed Walbro, hardest part was breaking loose the line from under the fuel tank that connects hard line to filter to hard line on pump assembly. Had to use a crescent wrench to get enough torque, while holding the stationary part (hard lines) with flared wrench.
    If you ever changed your plugs, doing the injectors is like 30 minutes more if you are in a rush.
    91 AWD TT
