I'd like to do this... Should be easy since I have a rhd ... Just gotta source the parts
I got a mirror, the controller, the switch, and harness pigtails from a wrecking yard in Canada. It was his only one, but if you check around you may find another. I also got a set of mirrors out of Japan through an Australian that lives there. The Canadian one may end up being extra when I'm done in about a month if you are interested.
alright let me know
I'm interested in seeing someone figure this out. I'll keep an eye on this![]()
Yeah I'm in for the results! I love gadgets and cool tricks in my car haha!
Nice, I love the power folding mirrors! I have a set however I'm not bothering with the stock control unit (mostly cause I picked up a cheap set on ebay without one). I'll be making my own, very easy actually since I've already done a custom power window (up&down/pass&driver) controller and it's basically the same board. I also will be doing further integration with some other things...
here is a link to modifying them to get the right angles (haven't tried myself)
1993 Mitsubishi 3000GT modifications | Car-Q
and here is a link to how to wire them in
SHOOTER83 BRO How do you wire Power Folding Mirrors?
Good Luck!
Antoni
Thanks Toni. I had the 1st link but not the 2nd. It doesn't indicate what to do with the brown and red wires coming off the controller so maybe they go to something unrelated.
The folding mirrors can be wired in without the control box, many of us in the UK with early mk1 GTO's have installed folding mirrors by using the central locking to activate the folding action when the car is locked/unlocked.
I managed to get a control box off a Mitsubishi Pejero 4x4 they all have the same system, but just different type mirrors, the control box should be located behide the radio above the ECU on JDM vehicles, I havent got round to wiring mine up yet but its a simple job.
This may help using the mitsi switch and relay box(control box) it is not to difficult using this guide i found.
On the control box:
RED/BLACK goes to acc +
BLACK goes to a ground
GREEN/YELLOW and GREEN goes to the mirrors fold motor (tap both motors together, and connect to these wires)
BLUE/YELLOW and YELLOW go to the fold switch
On the switch:
BLUE/YELLOW and YELLOW go to the control box.
GREEN/WHITE and BLACK/YELLOW are for the light, tap these wires into the cruise control switch wires (match the wires, and tap them)
the rest of the wires that are left, will connect to your existing wires for your power mirrors, just match them up.
On the mirrors:
GREEN/YELLOW and GREEN goes to the control box
5 other wires will be left, those go to the existing door wiring for the power mirrors, and heated mirror defrosters, just match up the wiring and connect.
TO WIRE IN WITH THE CENTRAL LOCKING WITHOUT THE CONTROL BOX.
NOT SURE ABOUT YOUR US WIRING COLOURS BEING THE SAME.
Remove your drivers door panel, there is a small loom that runs toward the door lock, in this loom there is a Blue/Black & a Blue/Red wire, get a twin core cable & connect it to these two wires, now run the twin core out of the drivers door & into the car to your mirror switch, pull the switch out & tip towards you so as you can see the wires, top right is a Yellow/Silver bands the Blue/Black side of your twin core needs connecting to this wire, next to it is a Blue wire, The Blue/Red side of your twin core needs connecting to this wire, your mirrors will now close & open with your central locking regardless of whatever alarm you have, i have done a write up with colour pictures but would need your or anyones email address to send it. this shows exactly where the wires are & also the easiest way to get your twin core out of the drivers door.
This is frikkin awesome!!!! The door to my garage isn't wide enough for the car and the mirrors to fit unless I fold one in. If I could do this by a switch would be perfect. I am in to see how this works out!!!
