The wife has a puddle jumper she takes from back and forth from Newark, DE to College Park, MD. Ford ZX2 2001, DOHC 2 liter, the other day, the engine dies on 95NB just before tunnel; she is able to pull it over to shoulder and get it towed home.
Electric is fine, fluids good, starter seems to be free wheeling; ie not engaging flex plate on ATX. I haven't had a chance to start pulling things apart; dang cold in the garage.
The car has 103k miles and I do not believe the timing belt was ever changed, its a non interference motor. Based on the symptoms/information, is it highly likely the timing belt broke![]()
Removed the timing belt cover to check things out. Timing belt is a little loose, but to my astonishment the front idler pulley is sitting on an angle, and after further investigation found the idler pulley bolt sheared off! It must have loosened and then after some fatigue stressing, snapped. Its an aluminum head, guess I will be using some extractor next weekend.
