As many of you know im sure, I have been having issues with my car smoking on and off at stop lights for about six months now. The day after I had the 3rd gen lifters installed it started smoking at stop lights. Blue smoke so it was oil. Just recently I came up with the money to have the valve stem seals replaced, the timing belt and well whatever else would need done.
I was reading on the valve stem seal replacement and it said to check your PCV valve which I had already done, but I was thinking and though well maybe the inlets and outlets that the valve is on are clogged. Well sure as shit, I take mine off and the side that does not screw in but goes over the "nozzle" was clogged. So the actual piece on the motor was clogged. I took a air hose and blew it out and random debris blew everywhere. I put the PCV valve back on and started it......
It was still smoking and even worse now, Pissed off beyond belief. As I was 60 miles from home when I did this I just drove home thinking that the drive might clear things out. Well, this morning I go out there and let it warm up and idle for eh ~2 min. Way longer than a stoplight and NO SMOKE! Let's just hope it stays that way. Maybe when installing the new lifters some gunk was loosened up and clogged it?!
So thats my good news. My ? to you is, what should be done now. I have a little extra money set aside now. Besides doing the timing belt, I am thinking about a lightweight Crankshaft Pulley, Not the underdrive. Just the Lightweight one from 3sx. It "says" it adds about 8-10 hp , any input on that?!
Also, I am thinking about doing all new motor mounts as I have a HUGE clunk when I hit the brakes hard or sometime when Itake off from a stop light , just not as hard.
Liking the new site! Gotta get my sig and avatar set up!
