so instead of methanol, which burns colder, but is less explosive I.E. you need more of it to get the same power as straight gasoline, what if I swapped the methanol with Toluene, which burns colder, and is MORE explosive than gasoline. I was looking into mixing this in a 7-3 mix with gas to average around 98 octane, but with how much my dad can get me from his work at one time, this is impractical. so what if I buy a meth kit, and use toluene instead. Idk how they work, but if it only kicked in at say 14psi and above, this would work a lot better I think. and as it's alot more explosive than meth, you could use a smaller jet which means you could use a lot less during a pull than you would meth. ....just a thought
DOOO EEEEEET! I'm curious what type of data you come up with on this.
