So I have taken the time to perfect the lower door trims I have created. These door trims replace the ugly carpet on the door made from high quality 14 gauge stainless steel.The front center piece of the door trim is cut out for the buyer to add what ever inlay they want to add, you can glue it on or tape it on the inside.
These door trims are a stock replacement which means there is no modification and no drilling needed to do on the doorpanel, you do not even have to remove your door panel to install these. I proved the hardware necessary for the installation of these as well. PM Me if you have any questions or want to purchase.
In the future I plan on making a full Stainless Steel Interior Trims for our cars including the shifter ring and speaker covers. These are also great if you want to paint them to match your current interior.
HOW IT'S MADE
