Surge FTW. When you let off, most (actually all because nobody seems to set them right thinking it's supposed to be closed at idle) aftermarket CBPVs don't release enough air and the rest stalls the compressor and blows out the intake, blowing off the intake pipe if it's not tight. Wouldn't surprise me at all if this was the base cause for a lot of people's smoking on decel problems with stock style PCV systems, 2 psi in the crankcase is more than enough to push oil past turbo seals when letting off. Just a random thought.
